  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
Okay, one frustrating thing with the 880.  There are no RCA inputs on the rear for the Satellite/Ipod whatever.  I have a satellite radio and am currently using the FM modulator--boo.  The manual says nothing, but is there some IP-Bus adapter that will just give me an RCA input?  The specs on the 880 say two inputs and I know there is one on the front, but wtf???
yeah, Pioneer makes a little adapter for that
IP-Bus to RCA
That is good anyway, I am sure they will give me the dumbest look ever if I go into BBuy and ask for one though. :(
http://cgi.ebay.com/829B-3E29-Triode-mode-...1QQcmdZViewItem
Going to see how far the bidding goes up in the next few days. I'd rather not pick up another single ended amp as I already have the SV811's, but...that's f'ing beautiful. And I've only seen one other 829B-based amp before.
Of course, now that I've said something about it, some jakcalope will drive up the bidding to over $1k and make me not afford it. That's usually what happens if I say anything :P
well, either my window is really, really gooed up by eDead now, or the window motor died
fuck
had that happen in my old car never fixed it...just stuck a pen in it and left it that way
it's my driver's window, and i hate driving with the windows up
Though i enjoy driving with my window down ive found that when cruising long distances over 50-55 its best to run the AC on low.
But how does eDead get gooed up in your window? was it mat or the liquid stuff?
mat
heat = melted tar
melted tar = eDead falls off panel and lands on window
eDead gets stuck at top edge of outer door panel and adheres itself to the window
ohh, bad. Not fun either.
I havent had any problems with my second skin though. I did some research and when i found damplifier withstands the most heat out of any other dampening product and it was cheaper than Dynamat and alot others with better dampening properties than brown bread and almost as cheap i went ahead and bought 80sq feet. now i have like 20sq feet lying around and im trying to decide where to do it.
Anyway, best of luck to you. :badmood2:
There's a Mac 240 in mint condition, currently at $750 with a couple hours to go.
But it's...boring. Just another push-pull tetrode amp if it weren't for the name :)
Jntar, you know you want a B-series in your SPL beater...gonna need it when you put 2 MT 15's in there :D
your old 55horse carburated engine aint gonna be loving life.
Its a trailor queen...and you forgot...each of the kenetiks are 75lbs :) Thats 300lbs just in batteries :rofl2:
jimbo...
the tubes in the tu 300c are 12ax7lp
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Say something :)
say something good to me. hey hey hey if its worht your while say something good to me - mariah carey "say something" :)
that can be our song if you like. :wub:
Edited by Devillain
jimbo...
They are small looking little guys too.
And I've got a matched set of 12ax7's too. About the best ones you can get from what I understand, I love 'em.
jimbo...
Most 12V signal tubes are the same size...12AU7, 'AT7, 'AY7, 'AX7 tubes all fit into the same socket and take the same voltages, the only difference is the amount of gain.
ok so here is the tally
300lbs in battery
120lbs in woofage
probably 160lbs in enclosure
20lbs in ampage
another 20lbs in wire
and 200lbs in operator.
I bet that CRX wasnt born thinking it would carry 820lbs of stuff. :wacky:
reguardless, 4 people in my buddies CRX when he had itmade it go from quick to mediocure with a B16...and the suspension squated.
That was probably~650lbs and he had stiffer suspension than stock.
