Not even a 5spd, if he went with the one that he showed us...
I don't understand, this is such a strange change for Dave. I hope he is feeling ok.
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
meh, couldn't pick a more boring car to me.
Lets hope its and Si, and Nick and put some forced induction on it.
Plane jane auto , about the only options are power windows and door locks . :)
Yeah , I asked he said yeah :D
This looks perfect for my computer speaker needs. If I ran something like this how would I power it? Also I would want to put a little 6.5" woofer for sub duty. How hard is it to build a crossover? Its something I've really been wanting to learn. and we've been going over current flow and resistance in Phys II so it seems it would go hand in hand.
Lastly how much would this setup run?
just tried to fg something...a little test on an old water bottle.
darn mat sticks to my gloves *crying*
Keep one hand resin free at all times. If your laying mat on a mold. I usually apply resin , then lay the mat over top of the resin , then dab it with the brush to remove the air bubbles . :)
:shrug:
A small integrated amp would work well for that. I'd go with vintage gear because 1) for the price range you're probably looking at, mass market gear sucks and 2) you won't need a lot of power.
Building crossovers is easy, designing them is not.
:shrug:
Maybe he got tired of having to park the behemoth 9 miles away from everything else :D
did it just like that and then tried to apply pressure with my hand :(
didn't try to press it with the brush though.
i wonder if it sticks to the brush...
remembered i need to strengthen the center console and i thought about adding a layer of fg on the inside. how could i make it stick to plastic ?
The crossover is pretty easy with the schematic, I don't remember the cost when I added it up but it wasn't all that much. As for power any cheap pawn shop receiver would do you justice. A ported mli6.5 with a 70w amp could make a decent sub to go with it.
I always put the mat on a piece of fiberglass and paint it with resin, then pick it up and put it on the object, then use the wet brush to push out all of the air bubbles.
Ramos > me though
more than a man, less than a god
If it sticks to the brush your in trouble, cause that means your resin is starting to cure. Better hurry up :D
Use epoxy resin instead of polyester is about the only way really. You can drill holes, or scuff the plastic really roughly to give the resin something to hold on to . But it will eventually come loose using polyester resin. :)
by a lot
Bah , I wouldn't go that far . :)
And you know this MMMMMMMMMAAAAAAAAANNNNNNNNNNN :)
I started listening to some of those records last night....thanks :)
I've got a friend in NC that has a record cleaning machine, some of them need deep cleaning but that's no problem.
Feel free to unload any more you want :D
Lot of people, not much posting :(
They have been sitting in my mothers garage for years lol I have some more , just got to dig them out :)
Done for the day, wooohooo
Now, sleep, so I can get over this sickness.
tried the brush shotrly after your reply and it didn't stick.
also turns out it didn't cure. i guess i put too little mekp :(
