Or maybe I will just go home and play with my balls :(
  • Replies 317.8k
  • Views 12.8m
  • j-roadtatts
    j-roadtatts
kinky...
Just wash up before you touch the Fostex...
kinky...
Speaking of which , my 67 year old mother thinks your "origami speaker" is "pretty" :)
ok so guy e-mailed me back about the TuLines...
" The overall sound of the TuLines is very good, in all modesty, but because the RS52 dome midrange has a large flange diameter and both woofers are running off the same crossover to the midrange, the integration of the four drivers isn't quite as good as one would want, and it would have been better if this had been designed as a 3-1/2 way instead of a 3-way where the lower woofer would have only been helping out with BSC and the lowest frequencies"
wtf does he mean? one rs180 is putting out a different sound, and needs BSC or that the midrange needs it?
What he's saying is that the second RS180 (apparently the one on the bottom) would have been better suited with a lower crossover frequency than the other RS180 (accounting for the "1/2" part) to serve as an acoustic Baffle Step Compensation approach rather than having both drivers accounting for the same bandwidth with no method of BSC, although there may be an electrical network solution in place. I'm not familiar enough with the network to say one way or the other although I'm sure he's bang-on with what he's saying if he designed it.
I assume this is Martin you're speaking with?
no this is paul kittinger.... he had someone else do the crossover for him
Without looking at the design, I can't really guess as to how significantly a BSC would (or would not) have helped. Most end users don't even know what BSC is and it's quite possible you'll be very satisfied if you build it.
6k to go. :)
Past $850 for parts so far, would be close to 875 when done.
parts for?
The super tiny actuator I am working on. Sorry was just sort of thinking / stressing figuratively out loud.
* RANT
SCREW pucking VIRGINIA TECH AND THEIR GOD DAMN THURSDAY NIGHT GAMES . TOOK ME 3 HOURS TO DRIVE 15 MILES ON THE DAMN INTERSTATE
*end rant
Nothing wrong with college football . Just leave the chit on SATURDAY WHEN PEOPLE AREN"T TRYING TO DRIVE HOME FROM WORK . :)
