OK...going to try to configure mIRC now...let's see if this works...
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
OK, I'm in #SSA, how do we do this sharing thingy?
Nobody else is in there.
Oh well, guess we can figure this out over the weekend...I'm having a hard time replacing all the files that I lost :(
Preston, the orange stuff is called Dex-cool, look in your owners manual and see if it requests it or not. I don't know what year your Tahoe is so I don't know if it would use Dex-cool or not. The oil pressure is fine, and don't worry about having it overfilled a little bit either, won't hurt.
It's a '99 so I think it should have Dex
Which is compatible with all new extended life antifreeze.
Oil overfill you need to be cautious on. If it's close to a quart or more, you can push it past the valve seals with ease. Then you have a nice smoky vehicle.
I'm thinking this 3sixty.1 is not going to work for me. Not compatible with windows on a PC which I was told it was. HAS to be a bluetooth enable Palm, or something with windows mobile. The owners manual makes setup seem pretty complicated as well. Might just have to sell this thing. Dammit.
good stuff tom.
I live 27 miles away from Virginia Tech :(
I'm 2 minutes from ND stadium. Total shit fest on home games. You can only go somewhere during the game. The entire rest of the day, forget about it. You cannot drive anywhere around town without it taking you 3-4 times as long as it should.
you have moved since I was there. :D
jeez i hope that's a 5page min and not max, with 5 sources that'd be kind of hard. especially with the one with 20slides and a 5min speech
Nooo actually, the first one is 5 page max I believe but the one with 20 slides is 5 page minimum. I think the same goes for the psychology paper, 5 page minimum.
I can fart 5 pages
Man you are having some serious crossover issues. If you want the DX let me know.s
Sexy! I like how the Impala is in front of the Viper :)
It's a Caprice with a 6.0L LS motor actually, damn quick car for a basically stock engine
LQ9 with L92 and a carb or efi?
IIRC, it's a LQ4 (earlier version of LQ9) with the stock heads, efi, and pcm
Yes, I have. 3 times actually.
I'm good, thanks though! I need something small enough to fit below the amps and this fit perfectly, but is a total pain in the ass. I thought it would be simpler, but no.
