so...i swear i've said this a million times before, but i really have good days. good enough to almost make be believe in planets aligning bullchit. Some days chit just goes my way, then some days nothing will go right.
today was a good day.
You're not alone...I've had numerous days when everything went super smooth only to have a horrible day after that.
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
ok...take that back...even though i'm breaking my own rule here, today is going better than good.
chit... good morning hop
tis too early
tis early, but has the potential to be a very good day here as well.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
What kind of port area should I look at?
maw10, correct? personally, 4" aeroport. help with box volume and will make for a far easier build.
and i'm off to drive the mini!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
correct, how do you make a curve with a circular port?
35 and sunny here! the snow is finally melting. I have to laugh at days like this when it's 35 out and feels like shorts weather. Two weeks of double digit negative temps and wind chills in the 20-30 below range really make you appreciate weather slightly above freezing. Too bad it won't last.
The warmer weather won't be lasting alright. Warmed up here to around the 0F temp, and a storm is coming in tonight, followed by -40F weather, before the windchill.
