Also curious to hear what the Capt. thinks of a CTS
Well, I had the pleasure of driving the '08 yesterday. Was stickered at $56,xxx ... ouch. Other than that, no complaints. Also drove the '05 with too many miles on it. I would have bought it on the spot if it had 30K less miles. They both drove real nice. Seems like a smoth powerplant in both as well. I actually fit in it so right off the bat that is a plus. I'm only 6'4 but even that is a tough squeeze in some vehicles - usually I don't fit shoulder to shoulder, though.
Definitely a better ride than the '05 Accord I drove. I like the responsivness of the 335i a touch more. Most comfortable of what I have driven in 2008 would be the IS 350 so far ... a real nice car, but I couldn't get it to respond real well deep in a corner ... very likely just my driving style, though.
Only beef with the CTS ... if I recall correctly, 4600 lbs? The 335i is a full 1000lbs less.
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
Naaa, make a sphere by taking a solid chunk and turning it into a ball, basically just turning a bowl.
Bowls are my favorite lathe project. I glue up hardwood scrap into panels and then glue the panels together. Make great presents ... and people were buying small candy dishes for $40+. I enjoy making pens, too - but only when I have the patience.
Would you drama queens to get a room already?
*sigh*
Glad to hear you've found something you like. :)
How do you hollow it out then?
Move the steady rest to coming in from the front of it.
Interesting
Would love to see this done
As already mentioned, you nove the rest to the front of the piece.
I'm guessing you are visualizing a chunk of wood mounted between the two points on the lathe. When making a bowl, you can just use a mounting plate and screw it to a piece of plywood which you glue to the bottom of the bowl.
Unscrew the plate when done, carefully knock the plywood off, and finish the bottom.
I like to apply a couple coats of polish with the lathe spinning and then use a big handful of chips/dust off the floor from the bowl, cup my hands, and rub it into the bowl (while still spinning). Shines it right up.
Interesting
Next time I turn something on a lathe I'll take a photo or three for you. :)
Could always use a nice wood bowl...................
J
Interesting
:woot:
J
Any particular size/specs or idears that you can come up with? I might be able to see what I can come up with. ;)
One big enough to either put breadcrumbs/crushed doritos in and roll egged chicken in to bake
J
