  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
nick, the thing is..it runs fine after it's started...no hesitation or anything that would lead me to suspect timing..i dunno, i almost believe the computer is somehow off on startup pressure and isn't sending enuff fuel at startup..pulse voltage could have something to do with that,correct?
ryan..it's not distributorless like the lt1 and up..electronic yes, but with a distributor. maybe a coil problem..hmmm
supa, i believe the crossfire was similiar to chrysler and gm's earlier attempt at crossing the intake runners (can't remember name) with dual carbs. the right side carb fed the left bank and vice versa, i believe it was an attempt to lengthen the intake runners making for a higher charge velocity. i also believe it worked better with the carbs then it ever did with the vette...it only lasted from either late 81 or early 82 to 86..after that tpi was born.
hey guys, u realize we are breakin the rules by actually haveing a constructive conversation?..lol...just making sure..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
ryan got 2000....but i got 2005...kewl huh???
post 2500 is the next official race...then to 5000
ready, set...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
DAMMIT!  You messed up my Beatle's tribute page!
they suck anyways....lmao!! i prefer the doors
or the grateful dead....or pink floyd...
And the LT1s do indeed have a distributor.  Unconventional, but a distributor none-the-less.
ur talking about the coilpack correct? looks like a block with 8 prongs sticking out of it??
that's not a distributor..lol...kinda close, but not quite..
SO i bought a Pioneer off SD for a local guy.  Guy on SD sure is taking his time.
:lame::worthless::banhim::ready2go::madsign:
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
i do indeed stand corrected, i was thinking of the later system..ur refering to the optispark ignition...
my apologies sir....
and no, the 87 has a conventional distributor..
no apology necessary. Just wanted to make sure you were more informed.
TPI, should have the standard rear mounted distributor.
I think you're on the right track though. Fuel and fuel pressure would be my first suspects.
LT1's have the optispark. It's a female dog too. I had to change mine out in the Z. Took about 8 hours because I took too many smoke breaks (don't smoke anymoer though)
i like my burb. Find me a suv where you can fit 3 full size batteries under the hood without making a major modification
