  • Replies 317.8k
  • Views 12.7m
  • j-roadtatts
    j-roadtatts
ramos, i have a forstner bit here with your name on it. If i head over to dave's today i'm going to drop it off there. i'm hoping to go over later if he's there and get the baffle all drawn out.
now...what is the product that i need to seal off the mdf? i know you know, but i can't remember the name to save my life
....i hope you misread my post, cause if not i'm definitely misreading yours.
i know the name of the shit but can't think of it, i keep wanting to say mar-hyde but that's obviously not it
all remaining 2008 NOPI events have been canceled it seems
not sure exactly what that means...but it sounds like it sucks
i've read a lot about shellac, may actually try that.
not going in my door, going on the zdts
yay.........................i have nothing to add
Are there any good references for 120VAC home wiring, something like BCAE except for 120?
I'm doing a simple, two-circuit outbuilding next weekend but I'd like to have a reference just to make sure what I'm thinking of doing isn't totally stupid in terms of sizing things...for example, I have some numbers in my head like a 2% allowance for voltage drop in power conductors but I'm not entirely sure if that's even right or not. Also not sure what they want for grounding...I can think of more exciting ways to spend a Saturday than pounding 10 feet of copper into clay :P
Grounding will be specific to your local codes.
How far away from the main breaker are you and exactly what all are you doing? Don't worry too much about voltage drop, with AC you usually get a 10V swing either direction. Size your wire according to amperage and you'll be fine. I was an electrician for 10 years, just so you know.
You can go to your local book store, or Lowes, HD, or Menards and pick up and Ugly's Book.
http://www.uglys.net/
Including the distance going up and down walls, I'm probably looking at an 80-foot run between the 200A main panel and the outbuilding. The only loads will be a fluorescent light unit and a quad box for power tools, I wanted to have them on different breakers so he won't be in the dark with a tool still spinning if he manages to trip it.
how is the exhaust going?
do u know of its location?
Sanding sealer , minwax sells a brush on kind that can be shot on with a gun ( I got a cheapy I can bring if needed ) or if your really lucky you can find the Deft sanding sealer in aerosol cans. :)
Dammit, the 350 was the twin, not the four :( Still may make an offer, won't be anywhere near what it'd be worth if it was the 350F though.
And the seller of the 550 four I was looking at obviously thinks this qualifies as "excellent condition":
Bad photo or not, that tank looks like it's lived a hard life...
