  • Replies 317.8k
  • Views 12.7m
  • j-roadtatts
    j-roadtatts
Reminds me, I used to be addicted to Unreal Tournament. My handle pissed people off.
When I killed someone the screen used to say, you have been killed by your mom's dong
You made sailor jerry and diet come out my nose.
Asshole.
mm, sailor jerry is tasty stuff
It's the only spiced rum I buy at the LQ
I suggest the Flor de Cana, the 7 year is fine no need to go older :)
what kind of reliable 200+ hp motor can be dropped in a 68-71 bmw 2002 for less than $10k?
5.3L!
x2
You can drop a 5.3L into a 240sx and the 5.3L is lighter than the stock block
Good luck fitting one in a 2002, the M30 would go in a lot easier, it would stay in the family, can make more power than that chassis can handle and is flat out one of the most reliable engines the world has ever seen.
**ahem** Testicles. That is all.
or one whoring session that may take place this weekend, we shall see. I can't just let you have the lead that easily.
Hey I aint hella behind
10k in posts...........i could wh0re that much
I may go see it for shits and giggles
K guys I am trying to convert RPM to MPH and have some questions.
Given
RPM - 3800
CVT Clutch - (Don't know ratio range for this) Assumed 1
Gear Ratio of Transmission - 2.68
Front Sprocket connected to Transmission - 11 Teeth
Rear Sprocket connecte to final drive shaft - 39 Teeth
Tire Diameter - 24 in
With all this I am calculating a speed of 26.8 mph, but the problem is our mini baja this year had this setup and was reaching speeds of atleast 30+ mph. I'm assuming that the CVT eventually goes into "overdrive" but I'm not sure of the ratio. A .8:1 overdrive from the CVT would put the speed at 33.4mph which sound more reasonable
Does this sound reasonable to you guys?
I am trying to figure out what kind of tranmission I want to use for the baja and we were considering a Honda Foreman transmission with a front dif used for the rear but by my calculations the top speed would only be 23 MPH in 5th gear which really isn't enough.
I'd do that calcuation in Excel and set it up so that the numbers and units are in different columns so you can check and make sure the units cancel right and let Excel do the math. This way you will know you are right and it will be uber easy to change values to see what happens.
No clue on the CVT, there will be some slippage though I would expect
Which is better?
randy with D in his mouth?
or randyd with mouth on his D
Wow. Wish that professor would have told me he wanted the freezer to reach -20*C rather than me assuming that he was talking in Farenheit, so I made it so it hit -20*F. Big fucking difference.
I'd discussed the freezer with him earlier, explained the difficulties of getting a cheapo deep freeze to reach -20*F, got it down there (lots of foam insulation), had it there for the past too weeks.
Now he finally says its -20*C rather than me saying Fahrenheit and him not paying a god damn bit of attention.
How about an M30 I6? Bulletproof and can give you way more than 200hp.
i am starting to plan out my next vehicle, i've had the accord for 8 years and even though it runs perfect i am itching for some change. looking at maybe 15k initial budget, which means 5k for the car 10k for the motor and another 5k for unexpected repairs (lol i know that's 20).
i know this is tons of work but i like this:
http://www.m2bmw.com/AlanRich.htm
That car is beautiful. :wub:
I would pimp the shit out of that. Might put a small chop in the top though. :coolugh:
