  • Replies 317.8k
  • Views 12.7m
  • j-roadtatts
    j-roadtatts
I am very impressed with my Sundown amps. :-D
I am getting a true 2k wrms with drop to 12.9ish volts.
looking at the HTC touch Pro. Actual possibility of using it as a temp car pc
you mean the touch pro 2??
I am having erotic dreams about that phone... waking up in cold sweat.
It's verry sad, but I remember every cell phone I had, but not the name of ever girl who has had my penis in their mouth.
I am thinking maybe this x2 with my maelstroms in it.
With my QSC amp they should see about ~1000 watts each perhaps.
http://www.avsforum.com/avs-vb/showthread.php?t=1093893
My only fear is then using a HPF at ~10hz, how much I would loose in the <10hz range. It's that or maybe sealed with some processing. I think I would much rather have more power to them at that point though so I could boost the bottom like a madman.
Amusingly I ran into that thread...yesterday. :P I have a wood project in my bathroom and want to have my sub for the living room planned so I can do them both at the same time. Way faster to do two very related projects than two separate ones : )
The original easy button was playing down to 5 hz :o
I am thinking this might be the way to go since my amp will only be pushing 1000 watts. I will need a HPF for under ~10hz, but how much do you think I will loose?
I'm having trouble deciding between running the pair of mael-x's in dual vented or dual sealed....
What will your living room sub be for equipment?
I really want to turn off the little plus/minus in the corner of every post. It blocks text on my work machine. I hope at home on the wide screen it looks better.
It doesn't get in the way for me and I'm running a 19" widescreen. Haven't noticed it in the way on my laptop though either.
:mario: Some days it seems like you are doing nothing but running in circles :Doh:
my circles are a little mis shaped and look like squircles
As long as it is all in good fun, it does not really matter :wacky:
As long as it is all in good fund, it does not really matter :wacky:
