Posted October 22, 200818 yr Trying to make this as simple as possibleI have 3kwrms @ 2ohm to work withroughly 12 cubes after displ. 45W 35T 20DWalled in a CC Truck4 15" SSD's Sealed or 2 BTL 18's and add another 2kwrmsI currently have 2 18" BL's ported but am looking for a little more spl. Its for daily and a groundpounder.I have my 18's in a 6 cube box tuned around 34hz, but they lack the real low end and high end response i was looking for. I wanted to do a sealed set up because its been a while since i went sealed. What do you think? Try 4 15 SSDs or just save up until i can get another amp and go btls in the same enclosure.thanks-
October 22, 200818 yr It's all up to you, really, as it is your vehicle. I think the 4 SSD's would be pretty cool in a wall.
October 22, 200818 yr Author thats what im thinking of going with as well. You think they would do well off 6 cubes a pair sealed?
October 22, 200818 yr Author i know, i would have them each in 6cubes @ 34hzHeres a pic of my current set up without carpet to give ya an idea.its 2 separate boxes but instead of 1 18 per box i would have 2 15's in them if i went the SSD route.
October 22, 200818 yr I like the idea of the 15's, but I am curious as to if they will be louder than 2 18's ported. I would wait for more input on this also.
October 22, 200818 yr Trying to make this as simple as possibleI have 3kwrms @ 2ohm to work withroughly 12 cubes after displ. 45W 35T 20DWalled in a CC Truck4 15" SSD's Sealed or 2 BTL 18's and add another 2kwrmsI currently have 2 18" BL's ported but am looking for a little more spl. Its for daily and a groundpounder.I have my 18's in a 6 cube box tuned around 34hz, but they lack the real low end and high end response i was looking for. I wanted to do a sealed set up because its been a while since i went sealed. What do you think? Try 4 15 SSDs or just save up until i can get another amp and go btls in the same enclosure.thanks-You're not getting real low due to 6 cubes each sub. Go bigger in box and lower the tune. Or get more subs to gain more spl. If you want to do sealed, you have to use ''Q'' series or 10'' and 12'' SSD subs.
October 22, 200818 yr Author alright, so in conclusion, what would you recommend? i just want to be louder without going hella crazy with power. Throw some ideas at me so i can start workin on a box and ordering some subs. :-)4 12" Q's ported? I honestly cant go bigger than 6 cubes per chamber its a rediculously tight fit as it is.
October 22, 200818 yr Could you measure of the dimentions of your truck and see if you could possibly squeeze 4 15" Q's into a ported box. You also could probably fit 6 12's in there.
October 22, 200818 yr Author Ok i have 43 Wide 20 Deep and 35.5 tall, however dont forget the width has to be in half because the onl way i can get it in is to use 2 separate boxes.21.5W 20D 35.5T Per Box.
October 22, 200818 yr Ok i have 43 Wide 20 Deep and 35.5 tall, however dont forget the width has to be in half because the onl way i can get it in is to use 2 separate boxes.21.5W 20D 35.5T Per Box.Why couldn"t you just make one box 45" wide, and pull the seats out to box in? I don't undersatand why it has to be 2 seperate boxes.
October 22, 200818 yr Author because im pretty sure the steering wheel would get in the way, and i dont see myself dissassembling my truck in that way. I normally just did it one by one through the passenger door.
October 22, 200818 yr Author Thinking something like this, but man are these dimensions Close, and this is with a 3.5" port
October 23, 200818 yr because im pretty sure the steering wheel would get in the way, and i dont see myself dissassembling my truck in that way. I normally just did it one by one through the passenger door.I see know, I didn't catch that it was a crew cab. For some reason I thought that it was an S-10. Is it a Colorado?
October 28, 200817 yr if your worried about height move the bottom subs to the outer edges along the bottom. and move the top subs towards the middle and down till they touch the bottom subs. that should give you and extra inch or so.
