Posted October 31, 200817 yr I have 2 stinger 680's and I am wanting to go with either 2 power master 680's or 1 powermaster 1200 and I am trying to figure out which would be better
November 7, 200817 yr Admin Can you give us a little more information as to what you are doing with them?
November 10, 200817 yr Author yeah I probably should have given you my system information anyway I have a 6000watt rms amp at 1 ohm and Im going to run it at .7 and right now I have a mechman 250 amp alt with a 3400d upfront and 2 stinger 1700's in the back along with 2 stinger 680's on the other side now Im thinking about switching the 680's for the powermaster 680's would but would it be worth it I mean I need every little bit of extra juice I can get and if the powermaster 680's are better then I will go with them or I could go with the powermaster 1200 as well but I cant fit anything much bigger than that cause Im out of room
November 10, 200817 yr what brand is the 6000 watt amp? We should have a thread, for teaching people how to use proper punctuation.
November 11, 200817 yr Author yep, I read it twice.You used no punctuation. You forgot to capitalize the first word in your sentence. So practice what you preach. Edited November 11, 200817 yr by Bdunn23
November 11, 200817 yr Author It's a Cadence ZRS9000d it does a true 6000rms at 1 ohm at 13.8 volts and I'm running 14.9 volts
February 5, 200916 yr Swapping used Stinger 680's for new XS Power 680's will make a bit of a differnece, but adding in the D1200 will make a very noticable differnce.
