Posted November 12, 200816 yr i have 2 saz1500d's.they are gonna be pushing (8)sdc2.5 10's.i figured they would be getting around 400ish rms per sub...i need more..to my question..would it be possible to run 3 saz1500's to these 8 subs?if so how?i have no problem running them below 1ohm.
November 12, 200816 yr We're going to need to know what impedance your subs are.But I can already tell you're attempting to make this more complicated.. Just run one large amp.
November 12, 200816 yr Author they r D4..im going to run sundown...period...if they made an amp that pushed 5k at 13.8 then id be all over it...plus i like multiple amp systems..this would save me alot of trouble of selling the amps then buying another.it is really hard for me to find the time to work on my truck b/c im stationed in FL right now and i only go home every once in awhile.(my truck is at home for now).so if there is any way then id be greatful
November 12, 200816 yr Three amps just doesn't work. You'd have to drop two subs.Either wire four subs to each 1500D at .5 ohms, or sell both 1500D's and buy a 3000D and run it at 1 ohm.
