After reading the FAQ, it seems that the speaker wire outputs are parallel wired inside the amp. I'm trying to wire a SAZ-3000D for a single one Ohm load. Do I need to sum the positives and negatives outside the amp or can I just pick one set of + and - and get the full wattage out of the amp. Thanks.
Carl
You don't need to connect them, use either +/-, they are connected on the inside.
You are just talking about the amp connections, right? Not the speaker connections, right?
I'm referring to the speaker connections on the amp itself.
After thinking about it, I used one pair of speaker connections. If they are parallel inside the amp, I wouldn't think it mattered which set to use, or be necessary to sum them outside the amp. It seems to be working so......................
