Posted November 22, 200817 yr After reading the FAQ, it seems that the speaker wire outputs are parallel wired inside the amp. I'm trying to wire a SAZ-3000D for a single one Ohm load. Do I need to sum the positives and negatives outside the amp or can I just pick one set of + and - and get the full wattage out of the amp. Thanks.Carl
November 22, 200817 yr You don't need to connect them, use either +/-, they are connected on the inside.You are just talking about the amp connections, right? Not the speaker connections, right?
November 22, 200817 yr Author After thinking about it, I used one pair of speaker connections. If they are parallel inside the amp, I wouldn't think it mattered which set to use, or be necessary to sum them outside the amp. It seems to be working so......................
