Posted November 28, 200817 yr Wondering on what options to order on the BTL subs for spl use only. Want to use 5,000 to 10,000 watts each. This is a new build in a 90 Astro van.
November 28, 200817 yr Wondering on what options to order on the BTL subs for spl use only. Want to use 5,000 to 10,000 watts each. This is a new build in a 90 Astro van.Get them fully loaded every option, and make sure you pick the SPL not daily option if its for burps and stuff.
November 28, 200817 yr http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153Id go with everything except cooling and universal.So Pchamfer, HiXmCoil, SPL, Induct Heat Ring.NO cooling and No universal option.
December 3, 200817 yr Wondering on what options to order on the BTL subs for spl use only. Want to use 5,000 to 10,000 watts each. This is a new build in a 90 Astro van.Get them fully loaded every option, and make sure you pick the SPL not daily option if its for burps and stuff.X2. BTL's are the stuff man.
December 4, 200817 yr In the right box for burps only, I would think they will take it. . .you don't think?
December 4, 200817 yr In the right box for burps only, I would think they will take it. . .you don't think?Honestly, I think (well really know) that you and a handfull of others on here could do this, and that you truly understand what 10,000 watts is.For the others, I think that if they somehow actually got 10,000 watts to thier woofers, they will need a ton of recones... That is just an absurd amount of power....
