How much Space would i need for 4 15s in a BP? just a roundabout so i could see if i have enough space.
I edited your title so that it made grammatical sense.
What are your goals for the system? I take it BP = bandpass? What kind of frequency range would you like?
I do agree.. What Hz's? ----Music or Burping?---- 4th order Bandpass or 6th order Bandpass?
I would suggest them in their own sealed box around 1.0-1.25 each. Loading into a common chamber of about 25-30cf. You would need to play with the front wave tuning freq to achieve the bandwidth you desire.
4th order would be the way to go, mainly for music/bassrace
you sure about 30cubes for the ported partition? dang, that would mean, the only way to get that would be a wall =/
i would say you should just go with a ported wall if your thinking about a wall. bandpass is so hard to get musical out of. and if you try bandpass... your looking at around a 30/60 split
The 30 cube suggestion is for the super efficient SPL bandpass boxes :)
You can do smaller for a "regular" bandpass.
nah, no wall, i'm trying to stay under the windowline
wouldi be ok to go with arround 14cubes for the ported side?
i know it's hard to design a bandpass that sounds good for music, but i got some friends with quite some knowledge on designing a good bp. just wanna make sure that it would fit, before i start to bother them
Edited by Biggy
would i be ok with 5.6cubes for the sealed and 12,2cubes for the ported chamber? or is that just too small for the nightshades?
what subs are you using? sealed or ported? if ported what kind of ported BP? Slot? round?
nvm it wazzzzzzzz a bit of a slow reply
