what kind of enclosure am i looking for? i have a 1995 lumina, and now im seeing what kind of box i should go for. ( i have a very large trunk. ) i think my MTX JH55 is a 4 cube box. and i still have room for a little more, could someone post the exact and best enclosure for the FI BL 15?
and is there any very good box builder for xp or vista? also could i get exact specs for the 15bl with cooling, daily, universal, and a red dustcap.
ALSO would a hifonics 1200ixd amp wire at 1 ohm be ok to power this amazing sub?
Some maximum dimensions would help. . .like dimensions of the current box and how much larger it can be in each direction. . .
Brian
i dont quite understand how to use the flash box calc could you do it for me or explain it? thank you 1 ohm btw
Fs: 35.1 Hz | 34.5 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 6.23 | 6.34
Qes: .47 | .43
Qts: .44 | .40
Mms: 232g | 240g
Cms: 0.089mm/N | 0.089mm/N
Sd: 810cm^2 | 810cm^2
Vas: 81.6 l | 81.6 l
Spl: 90.6dB 1W/1m | 90.7dB 1W/1m
Bl: 12.8 N/A | 19.0 N/A
Xmax: 21mm
Rms: 1000W *
Sealed box: N/A cuft
Ported box: 2.8-4 cuft @ 30-37Hz
Sub OD: 15.625
if you find 1 let me know your box would be pretty easy i was looking at TurboBass Express
