Posted January 10, 200916 yr what kind of enclosure am i looking for? i have a 1995 lumina, and now im seeing what kind of box i should go for. ( i have a very large trunk. ) i think my MTX JH55 is a 4 cube box. and i still have room for a little more, could someone post the exact and best enclosure for the FI BL 15?and is there any very good box builder for xp or vista? also could i get exact specs for the 15bl with cooling, daily, universal, and a red dustcap.ALSO would a hifonics 1200ixd amp wire at 1 ohm be ok to power this amazing sub?
January 10, 200916 yr Some maximum dimensions would help. . .like dimensions of the current box and how much larger it can be in each direction. . .Brian
January 10, 200916 yr Well you will have no problem at all with room.Go for 4.5 cubes @ 30hz to get a low low boom.
January 10, 200916 yr Author and is there a great box building program out there, i have bbp which doesnt tell me alot lol
January 10, 200916 yr Well all I did was use the 3D flash box program over at RE audio.And my box turned out perfect!
January 10, 200916 yr Author i dont quite understand how to use the flash box calc could you do it for me or explain it? thank you 1 ohm btwFs: 35.1 Hz | 34.5 HzRe: 0.75 Ohms/coil | 1.5 Ohms/coilQms: 6.23 | 6.34Qes: .47 | .43Qts: .44 | .40Mms: 232g | 240gCms: 0.089mm/N | 0.089mm/NSd: 810cm^2 | 810cm^2Vas: 81.6 l | 81.6 lSpl: 90.6dB 1W/1m | 90.7dB 1W/1mBl: 12.8 N/A | 19.0 N/AXmax: 21mmRms: 1000W *Sealed box: N/A cuftPorted box: 2.8-4 cuft @ 30-37HzSub OD: 15.625
January 11, 200916 yr if you find 1 let me know your box would be pretty easy i was looking at TurboBass Express
