Posted January 10, 200916 yr ok wat up guys i just ordererd a 15" bl flly loaded BUT i chose the extreme lead option and wasnt aware that this was for spl applications only and not for dailymy question is what is going to happen if i run this option daily?my setup is 92 hatchbak mustang with a brutus hifionics 1606d and da bl 15",Thanks
January 10, 200916 yr If you just ordered it then im pretty sure you can email nick or scott at fi to get it changed.
January 11, 200916 yr Author so i should def have them change that out? is it gunna ruin the sub if i dont? im anxious to bumb this beastly looking woofer asap so what should i do?
January 11, 200916 yr Author ok i sent an email but the thing is i got the sub already it came a few days ago so basically there is no way i should be using this option for my daily system? what will happen to the sub
January 11, 200916 yr Just wait till you talk to nick... I don't have an answer for you because I do not know
January 11, 200916 yr O.I was under the impression that you "just" ordered them.Still you need to talk to nick about getting it fixed.
January 11, 200916 yr ok i sent an email but the thing is i got the sub already it came a few days ago so basically there is no way i should be using this option for my daily system? what will happen to the subSince they changed the way they do the leads I'm not sure on how this option is executed. But it was a thicker lead added for SPL purposes and could create tinsel slap when playing music. My question to you is what do the leads look like on the sub? Are they above the spider or sandwiched in between spiders?
January 11, 200916 yr I would just run the sub as is. If a problem develops, then you can take nessessary steps to resolve it.
January 12, 200916 yr The original extreme lead option was heavy wire (as used in the BTLs). We added this as an option for the people wanting to use the BLs for SPL high current applications where the standard lead has too much resistance and could be an issue. It was not intended for daily.BUT, since we switched to the integrated lead setup, then extreme lead option simply adds an extra set of wires to the mix. No issue for daily whatsoever and just increases the current carrying load. Nothing detrimental by any means.Thanks,Scott
January 18, 200916 yr Good To Know, I'll Get The Extreme Lead Option On My Next BL If It Helps Thermal And Mechanical Power Handling,
