Posted January 17, 200916 yr Alright either want 1 10" Q with BP Power or 1 12" SSD with BP Power and either the copper or flatwind cable... How many watts should each handle and which one should i go with? I want more of an SQ setup but i also want people to hear me coming down the block when i feel like turning it up.
January 17, 200916 yr ... there is a lot written about this two subs ... use... i would go with a 12"Q @1000W,2cubes,30-36Hz ...
January 17, 200916 yr Author nothings coming up on the search... and i have a f150 so i cant fit the 12" Q... So either 10" Q with BP power or 12" SSD with Bp power and either copper or flatwind coil
January 17, 200916 yr Author i have a Ford F150. the sub is going under my back seat. i am getting a seat lift so i can fit a sub with 6.5-7 in. mounting depth... The 12" Q has 7 in mounting depth while the 10" Q and 12" SSD have 6.5 in... i want to give myself some air space
January 18, 200916 yr Author Alright how big of an amp should i hook up the SSD with bp power and the copper coil?
January 18, 200916 yr Author not much... under $500... I was looking at the sundown sae 1200D and 1000D. which one would be better?
January 19, 200916 yr Author BL 12's are 6.75" deep.Yeah but they require a ported box. so they wont fit. trust me ive already talked to alot of f150 people and they said either 10" Q or 12" SSD
