i just need a wireing digram if anyone can help me out my buddy got the package deal and its the first time ive tried to hook up a amp with the four conections?
The saz-1000d is a mono-block amplifier meaning it only has one output channel. The four connections are for easier wiring of multiple subs. You can hook up each + and each - from the sub straight to each of the connections on the amp. You don't have to use all connections though since they are all in parallel inside the amp.
Yeah if you just hook up each + to each + and each - to each - it will be a 1 ohm load.
