iv'e been doing some reading and am thinking of buying a saz-3000d to run my Fi q series 15's in my system upgrade. my question is a ho alt a must or will i be able to get by on factory for a while ? i have been looking around for an ho alt for my car but it seems like it's going to be hard to find one.
I have a 2005 sonata four banger not your everyday base mobile.
A must.... not really. It all depends on with you are going to do though.
Edit: Some how it sent the message to quick...
If you are going to burp it, you will probably be fine with the factory alt. provided you have enough batteries. Although, you will have to charge them with a battery charger like I do.
If you are going to demo a lot, then yes an alt. would be something you need to look into.
If you are trying to run below 1 ohm, don't even think about it. Unless you have a large amount of batteries.
If you are resting at 1 ohm, you may see raise up to 3 ohm. A factory alt. will get you by, again provided you have the battery power.
Edited by banginAltima
not really.
i heard those amps can run on stock alts.
but you should have some batts to back it up.
i plan on running 3 batts on 3k also. but i believe blazers have 120 stock alt(could be wrong)
if your alternator is somewhere between 70-110 amps (which i assume it is) you will need a few extra batteries to see half of the 3k's potential. i will say from personal experience a 1500 is even a strain on a 90 amp alternator and an upgraded battery. i'm going to add about 100AH worth of battery and see how it runs, i would expect to run two or 3 times as much battery for a 3k.
this is going to be a daily street beater not going for numbers or anything like that, just want to have a good low end.
Same question here. My amps just arrived today. The SAZ-3000D will be pushing two 15" Nightshades D1. I bought a Powermaster D5100 for under the hood and a D3100 for the back. My stock alternator is 90amp in my CR-V. The best I have found so far is an Iraggi 200 amp. I plan on ordering that in the next month or so. I just hope those batts can handle that amp for a while. I'm just gonna have take it easy on it until I get my HO alternator. Hey, I need some break in time for my subs anyway. I just don't want to cause any damage to that 3000 by not providing it enough power.
Im in the same boat as you, but off the recommendations i got off CA.com I should be fine.
Ok...... not many believe this..... but i saw it with my own two eyes...
2 SAZ-3000's running at 1 ohm at full tilt...... stock alt, and ONE yellow top....... held a 14.7 through his Street Beat run...
MLA FTW!!!!
might not be a must, but its worth getting. when i got my saz3000, i didnt put it in till i had my h/o alt in and 2 extra batts in the trunk
but there is a guy who host some local comps around here with a rd audio3250( ive heard its the same board as the saz3000) and he has stock alt and batt, and it still does some nice demoing before we start comps
MLA FTW!!!!
Must have had a huge impedance rise.
MLA FTW!!!!
X2. There is no way they are putting out 6,000 watts. He needs at least 600 amps to even get close. And if he was running 6,000 watts he needs to do some research because he should be pulling more than a 147.
MLA FTW!!!!
I THINK by 14.7, he meant voltage wise, not his score.lol
MLA FTW!!!!
Oh haha. Yeah I think not... He has to gave his voltage coming from somewhere. 600 amps on a stock alt and one yellow top? Dream on.
i read that today.. i didnt say anything... cause theres no point.... as he stated alot of people dont belive but...
it takes power to put out power.... there is no way around that... not even an MLA... it only makes voltage higher.. not amps...
75 amp hours will not cut it. .. if you wanna say it prove it.
as far as the OP...
if your gonan run 3000 watts on a small alt get batteries and a voltage meter.... watch your voltage,
IMO... try it... but you better have cells.
...Dude, I'd Get The Alt, You WILL Need It With A SAZ-3000D To See It's Full Potential.
Try The Company Site That Makes The WMD And WMD2 Woofers. Can't Remember The Brand Name. Peerless Or Something.
They Have A Link To Very Cheap Good Quality H/O Alts For A chitload Of Vehicles.
well hes not saying he WONT get one.. hes saying that he wants to wait to get it.... save up a lil im guessing...
Ah, I See, Nice Lookin' Out Liljon. I Found The Link.
H/O Alts
These Probably Aren't As Good As Iraggi's Or Powermaster's, But They Got The Job Done For Me.
Of Course, They Don't Have Any For A Damn Hyundai. :|
Pierce Audio Products ;)
Your stock alt might not last too long on a 3000D. A HO rebuild will be cheaper (an lighter) than piling batteries in your trunk. I installed a 3000d on a 120amp alt and an HC2400 and still couldn't hold 12V for very long.
At least upgrade the battery though.
I would also mention that your warranty might come into question running the 3000d on the stock electrical.
I've spent so much money already, what's another $400. I just sent an email to Iraggi to buy the highest output alternator they make for my vehicle which is the amputator 200amp/90amp idle. It was actually the same price as a 180 amp from http://www.motorcityreman.com/high-amp-alternators.html
Edited by rk772
It is recommended to have a H/O alternator and a good rear battery to properly power the saz-3000d. You can get away without the alternator but you'll need at least two good size rear batteries such as the PowerMaster D3100s. For the price you're going pay to pay for the extra battery in the back you might as well just buy the alternator.
Look my Mercury Cougar has a stock 130 amp alt and when the stock speakers hit the head lights on the dash go dim..
Just buy some good batteries to back it up..
You think one D3100 on a good electrical wud hold up for a 3000D?
Edited by ohhsosmooth
