i know 1.5-2 cubes per is key... with subs i'll probaly see 4.4 cubes... would i be fine running a 1500 d on each until i get my other 2 nightshades, which will be very soon for some i can have now for the moment.
I can't imagine 0.5 cubes will make any real difference in power handling. And if you're worried about it, just set your gains conservatively.
so by saying watch your excursion, pretty much just watch out for stress or over-working of the woofer right?
the movement of IN and OUT
bigger box = higher efficiency = more output for the power you have available :)
may have to get that done in the next few weeks... box may need some bracing and a second baffle, that's about... everything else is done!!!
cool... and nmssd12 what do pics of... the box or the subs...
Of your build as you progress.
i can get pics of the amps and batts all set up in the trunk now... i have the ns's at home and will put up picks when completed...
  • 2 weeks later...
just put the shades in yesterday and i am totally satisfied with the products... the box is not carpeted yet and no vanity panels up yet... just is just a temp setup. future plans involve 3 ns's on 3 1500ds. i have my gain @ the 9:00 position and still breakin em in. they push so air which is great b/c my backseat does not fold down... they sound very good on music for my taste. they get low decently until i get a proper box built. A++++++ products here...
i'll post pics when i can... internet down at home should be up this weekend. how can i get the most out of these subs in what type of enclosure... i have as you know in about 4.25 cubes @ 35 hz... sould i go smaller or maybe a diff. type of box?
