Posted January 31, 200916 yr What is the exact optimal box volume, port opening (wxh) & port depth for two 15" NS vented tuned to 30~32hz
January 31, 200916 yr 3ft net works well. For a nice daily setup I recommend two 4" aero ports. If you prefer slot port then go with around 40" of port area. Here's an old vid of mine when I installed my first set of NightShade 15s. That box is 2.9ft net volume w/ two 4" ports per sub tuned to 36hz. It metered mid 150s legal.
January 31, 200916 yr 3ft net works well.Is that 3ft net per sub or 3ft net for both. Edited January 31, 200916 yr by rk772
