Posted February 4, 200916 yr Does any one know what the real outputs are for the vlx-400 at 1ohms on 14.4 and 16 and can it take 18v?I have one I am either going to use or sale I have had it for sale for sometime but no body buying in this market so I might as well use it.Someone said it needs like 350amps to run good is this also true??
February 4, 200916 yr It will go into protect after 15.4 volts. Don't run it on 18v's, it will go up in FLAMES.
February 4, 200916 yr Not sure on the amperage or voltage questions, but here are specs: http://ampguts.realmofexcursion.com/USAmps_VLX-400/
February 4, 200916 yr Author It will go into protect after 15.4 volts. Don't run it on 18v's, it will go up in FLAMES.Ok so I will stay at 14.4 I thought for sure this thing could take more, being a freaking HUGE.. lol
February 4, 200916 yr It will go into protect after 15.4 volts. Don't run it on 18v's, it will go up in FLAMES.Ok so I will stay at 14.4 I thought for sure this thing could take more, being a freaking HUGE.. lolThese amps were a product of the early 90's when 12 volts was pretty much all we had to work with. Those are even more rare than my old 50C.
February 4, 200916 yr Just like all of the OLD School US Amps this beast was rated at 12.5 volts. I have seen these beasts make well over 3800 rms with a proper load and voltage. But again they are going to want well over 400 amps to do so.
February 5, 200916 yr Author Sure here is some pics..This is all my amps and subs herehttp://s357.photobucket.com/albums/oo17/re...dioinc/?start=0
May 15, 200916 yr sorry for my bad english.I have questions to the amp.1.I have read the line-input is from 150mV to 3V.Is this right?Or is the input higher? to 9V?10V?or more.2.I will bridge the amp.I have 2 Woofers with Dual Voic Coil 4OhmMode is for 4Ohm not 1Ohm.I have take + from one side and - form the two side for one WooferAnd - from one side and + form the two side for the other woofer.tanks!!! :bigclap: Edited May 15, 200916 yr by powercap
June 18, 200916 yr the usamps vlx400 will take 16volts all day no problem at all i have had a lot of the old usamps and thay love the 16volts and the vlx400 will make 4178rms on 16volt and 432amps of curent you have to feed the amp alot
June 20, 200916 yr Admin the usamps vlx400 will take 16volts all day no problem at all i have had a lot of the old usamps and thay love the 16volts and the vlx400 will make 4178rms on 16volt and 432amps of curent you have to feed the amp alotDo you have the same user name for ebay?
