Posted February 4, 200917 yr i currently have a crossfire vr 2000d and an optima yellow top with a kinetik hc600. running 0 ga from the battery then 2 ga from the kinetik to the amp. im currenty upgrading the "big 3" and am looking at an alternator around 200 amps or so. is that enough upgrade to feed that amp? the type of subs i was looking at are the FI BL15's which are 1000w rms and also the RE AUDIO sx15's which are rated the same. also if anyone would recommend an enclosure not only for daily but for comp. as well....probably somewhere along interchangeable ports
February 10, 200917 yr i think nick said that the ssd's are like the sx with copper coils. the magnet is stronger on the ssds though.
April 13, 200916 yr Well i have a 220 amp DB Electrical alternator and 2 optima redtops in my suv. 1 up front and 1 in the back and it works fine on my 2 BL 15's. That amp draws a deasn't amount of current thoe 240 amps. The Certificate of power for mine says 2745 watts at 14.4volts. My subs are in a 6.2 ft net box at 36hz and it slamms.
