Posted February 9, 200917 yr Is it possible for a lanzar 2000 to power 2 15" FI BL FL and still have 1100 watts to each? thanks
February 9, 200917 yr Is it possible for a lanzar 2000 to power 2 15" FI BL FL and still have 1100 watts to each? thanksPossibly if it were ran at .5ohms but I wouldn't advise it unless you have the electrical. It puts out 1600 at 1.3ohms
February 9, 200917 yr That is kind of an insult to those subs. By the time you get them moving with that amp, the THD and clipping is off the charts.
February 9, 200917 yr I'd look into another amp, those aren't going to do rated power.Agreed, there are better quality amps out there. If money is an issue look into Sundown or Kicker referbs.
February 11, 200917 yr sundown 3000d and call it a day its more than enough power and if you set the gains right you won't have to worry about blowing them plus it will sound super clean.
February 11, 200917 yr wat about a Sundown 1500?to power 2A pair of SSD's and that amp is a solid setup...You don't have enough power for the BL's..but if you've already purchased then you need to look for something in the true 2500 watt range.Thanks!Nick
