  • Replies 81
  • Views 11.9k
  • 4 weeks later...
  • 2 weeks later...
Still working on perfecting them... will be doing more testing soon.
What do you say is a rough estimate on box size in cubes for a single 12 when these come out? I don't have alot of room in my xB but I sure would like to put one of these suckers in there. If I don't have enough room, I might say screw it and make a wall for a single 15 or 18.
About the same size boxes as the Nightshades.
1.5 - 12
3 - 15
4-5 - 18
Totally depends on the setup... from 140 - 150 somewhere in there ;)
I have a regular Nightshade breaking 154 with four 1500s but not every setup will do that.
Will you warranty the sub with that much power? :wacky:
Nope! You can buy re-cones, though :)
1.5 - 12
3 - 15
4-5 - 18
so you're telling me an 8cuft box will work beautifully for two 18 NS?
wow, that's what I need for my two fi 15's to perform optimally, that makes me think...
1.5 - 12
3 - 15
4-5 - 18
Correct. 8-10 cubes is what people are using for two 18s and it works great.
I need a pr. of 10's like yesterday! LOL
I'm shredding spiders left and right trying to bassrace with my AQ's and 2 5k's. :lol:
Nightshade-x is not yet for sale? it will take after the summer?
  • 2 weeks later...
Back for testing.
The motor force is lower than we anticipated so this prototype may end up as the Nightshade v.2 next year :) The motor force is dead on for that.
Made some changes to reduce moving mass compared to the Nightshade - so SPL should be improved along with power handling.
The latest built prototypes are D4 coils for testing purposes.
Testing two 3000Ds @ 1 ohm each now on one of them in my single 15" enclosure - results are very good so far :)
Will post shortly.
I am clamping power as well - I am impressed ;)
Results coming once I fire off a few more burps.
Peak score :
153.4 dB (did not clamp power this time)
Power Clamp Results :
Volume 35/50 - 148.8 dB / 1230 watts
Volume 40/50 - 152.0 dB / 2990 watts
Volume 50/50 - 153.3 dB / 4960 watts
Since adding new dampening to the floor and changing my amp rack I haven't tested for a new frequency - I am still using 53 Hz like from my dampener log. I also have not played with box position yet - with my new rack the box is farther forward than before.
So - it could probably be a little louder but I am just playing around with the prototype right now :)
I am using my Extech True Power clamp - holding the burp for ~5-6 seconds to get my reading.
