Posted March 3, 200916 yr how much does a 18" btl re-cone run? it is the older model. d1i tried to look it up on fi's site but it wont opena guy over on smd is selling an older model btl with broken tinsel leads on them. is this what a re-cone entails. are re-cones an expensive process? Edited March 4, 200916 yr by johnecon2001
March 3, 200916 yr Leads can be replaced. If it is done right, it will work. If not, they just fail again.You can recone it and get the new style leads. . .recone pirces vary by size.
March 3, 200916 yr If the Tinsels are in plain view (ie, not in the spiders) you can fix it yourself with out a recone.
March 4, 200916 yr Author what would be the extent of repairing a sub. does a recone make it basically a new sub again? the subs are 18" btls (old style). i am talking to a guy about buying his sub but it was owned by someone b4 him who had a stetsom 7k to it. i know they can be reconed but if i get into a jam that the subs need repair what is the most that can be done without basically purchasing a new sub thru repairs? basically is there anything that would just totally screw me and i would end up with a sub that cant be repaired or will cost a fortune to repair?
March 4, 200916 yr I *THINK* that if you read a little more into that topic, you will see someone said it is $105 per recone.
March 4, 200916 yr If the Tinsels are in plain view (ie, not in the spiders) you can fix it yourself with out a recone.by soldering? I have a friend with some like burnt/ broken tinsels at the end at the speaker terminal and I would just like to know
March 4, 200916 yr Author no no i got that part but i asked about the recone making the sub like "new." as well as any other repair that could negate the advantage of me buying it used and saving some money opposed to new
March 4, 200916 yr Author If the Tinsels are in plain view (ie, not in the spiders) you can fix it yourself with out a recone.by soldering? I have a friend with some like burnt/ broken tinsels at the end at the speaker terminal and I would just like to knowlol friend huh?! u funny. u tryna be slick? we r looking at the same subs right?
March 4, 200916 yr If the Tinsels are in plain view (ie, not in the spiders) you can fix it yourself with out a recone.by soldering? I have a friend with some like burnt/ broken tinsels at the end at the speaker terminal and I would just like to knowhttp://www.soundsolutionsaudio.com/forum/i...showtopic=19673
November 13, 200915 yr Leads can be replaced. If it is done right, it will work. If not, they just fail again.You can recone it and get the new style leads. . .recone pirces vary by size.hey man i have a 18 btl new models but i dont know how to re cone it and i email the fi dealer and they never reply i dont kno wat to do with it is it easy to re cone it by yourself
November 15, 200915 yr Probably because there aren't any Fi dealers...If you email us without a subject in your email it automatically goes to spam. As well as if you have an email consisting of something like ' imtoosexyforstifflersmomsboobs @ wow . com'Recones are easy to do yourself..just 3 glue joints and a little bit of solder.
November 18, 200915 yr Not to butt in or anything but i have a old style as well with a broke tinsel that i know i can fix. But i just need some tinsel does any one have any????
November 24, 200915 yr I just paid 150 shipped for 2 Fi BTL Recone kits including 2 frames and a VC spacer. Edited November 24, 200915 yr by DD9915D!!!
