Posted March 8, 200916 yr can i max the gain on the saz1500d without breaking the bl? is 1500wats the max wats that a bl can handle? or can it handle a little more? and what can a saz1500d really produce? coz i know its under rated, thanks!
March 8, 200916 yr Admin You should never max the gain on any amplifier regardless of the driver. The BL can be safely used with the SAZ-1500D if you are smart with gains and don't push the amp into clipping. The 1500D's have been tested show upwards of 1700 watts on a stout electrical system.
March 9, 200916 yr same setup i have right now just got it in 2 days ago. everything sounds good to me
March 9, 200916 yr You should never max the gain on any amplifier regardless of the driver. The BL can be safely used with the SAZ-1500D if you are smart with gains and don't push the amp into clipping. The 1500D's have been tested show upwards of 1700 watts on a stout electrical system.True, mine do 1800 rms a piece at .5 ohms and I don't even have the gains maxed out.
March 9, 200916 yr From expierence the BL's WILL take a 1500d full tilt. I use to run 2 15" BL's of 2 Sundown 1500ds! I could wang them ALL day long. They would get hot but I never really smelled any coils. My voltage was down to like 11.7 to.
