Building a new box for my 15" nightshade. Going to be running (3) 4" external aeros and was thinking about ~2-2.5 cu ft before displacement.. Will be testin different port lengths after I get the box built to see what does the best. Any input?
Hopefully 3000rms of clean power. Lol
What kinda of clean power is it a calss A-B
noo...... :Doh: :Doh:
A clean not distorted non clipped signal. :suicide-santa:
So in other words you will be running the amp properly lol no offence
And the H/U set properly, with good grounds/power, and wiring. then YES the "amp" properly :shrug:
nice it always better when the amp is running right. I blew lots of subs last summer because I didn't know my A$$ hole from my elbow lol
sundown 3000d! I hade Mike465 off ca.com build me a slot port of 3 cube at 36 hz but it only hit a 143.9 off a 38 hz tone so I am going with a different box design to see if it will get louder. Its a 3000d running off (2) deka 9a31, (2) runs of 1/0 and an exide orbital replacin stock batt.
Damn I'm good! lol :bigclap:
How do the Alpines like the 125.4?
I am in the market for ALL new speakers. And need something that sounds good and can take the power of my 100.4
It's only a 125.2, I am selling them and going to get some CDT or PG or something. They are only rated for 75 rms at 4ohm and the amp is rated 125 at 4 so I need some that can take some more power.
I appreciate it but I can design one that will work I just didnt know if I should make it closer to 2 cubes or 2.5 cubes??
i built mine right at 3.66 cubes with two 4in. arrow ports tunned to 34hz :bigclap: and yes i can be herd before i am seen.
