do you think the Crunch GPV2000.1 can do 2k watts rms 1ohm at 13.8v but it only has 4 25amp fuses.. for 2 fi bl 15s? or should i just run 2 amps?
GPV2000.1 1 x 500 @ 4-Ohms, 1 x 1000 @ 2-Ohms, 1 x 2000 @ 1-Ohm Maxx
no ...it should do 1000Wrms @1ohm ...
and how is this under Fi technical ?
Edited by Tyan
.. for 2 fi bl 15s?
GPV3000.1D-PRO is rated at 3k watts rms. not sure about the amount of fuse amps
Plus i have a d1 sub so im going to wire them like so
so i dont have to run them both at 2 ohm
Edited by Julian
http://forum.soundpressure.com/showthread.php?t=4030 i'm running the 2008 model, i'm sure their anniversary model will be just as good or better. and all their amps will do within 10% of rated power, that's maxxsonics standard, except for the crunch pro amps, (only the 3000d models) and the hifonics XXV models, they are tested to push their power at 13.8v, and that's the full rms they are rated for, XXV's and the 3000d-pro amps are absolute beasts...
