Posted March 11, 200917 yr do you think the Crunch GPV2000.1 can do 2k watts rms 1ohm at 13.8v but it only has 4 25amp fuses.. for 2 fi bl 15s? or should i just run 2 amps?GPV2000.1 1 x 500 @ 4-Ohms, 1 x 1000 @ 2-Ohms, 1 x 2000 @ 1-Ohm Maxx
March 11, 200917 yr no ...it should do 1000Wrms @1ohm ... and how is this under Fi technical ? Edited March 11, 200917 yr by Tyan
March 12, 200917 yr buy two cause crunch is overrated and 1 amp per sub is better...or just buy one big amp
March 12, 200917 yr Author GPV3000.1D-PRO is rated at 3k watts rms. not sure about the amount of fuse ampsPlus i have a d1 sub so im going to wire them like soso i dont have to run them both at 2 ohm Edited March 12, 200917 yr by Julian
March 12, 200917 yr Author how many fuses does it have? i cant seem to find any... because it would have to be atleast 200 amp fuses all together
March 13, 200917 yr http://forum.soundpressure.com/showthread.php?t=4030 i'm running the 2008 model, i'm sure their anniversary model will be just as good or better. and all their amps will do within 10% of rated power, that's maxxsonics standard, except for the crunch pro amps, (only the 3000d models) and the hifonics XXV models, they are tested to push their power at 13.8v, and that's the full rms they are rated for, XXV's and the 3000d-pro amps are absolute beasts...
