Posted March 16, 200916 yr Ok so i have a FI BL 15 Fully loaded powered by a Sundown SAZ-1500d.Ok so anyway when i play some music loud i hear some weird sound like the sub it bottoming out but i know its not becuase its not moving enough to bottom out.
March 16, 200916 yr Author Wires crossed? Whats the gain at?Gain is a little lower then half way and i don't think they are crossed.
March 16, 200916 yr K then it may be the signal cables. They might be bad.Edit: typed to fast Edited March 16, 200916 yr by brsteinbach
March 16, 200916 yr Wires crossed? Whats the gain at?Gain is a little lower then half way and i don't think they are crossed.thats probably your problem, your probably clippin the hell out of it. set your gain with a dmm
March 16, 200916 yr Author Wires crossed? Whats the gain at?Gain is a little lower then half way and i don't think they are crossed.thats probably your problem, your probably clippin the hell out of it. set your gain with a dmmWell i dident think it was cliping cause the sub was really not moving much
March 16, 200916 yr Wires crossed? Whats the gain at?Gain is a little lower then half way and i don't think they are crossed.thats probably your problem, your probably clippin the hell out of it. set your gain with a dmmWell i dident think it was cliping cause the sub was really not moving muchjust because it doesnt move much, doesnt mean it isnt being clipped
March 16, 200916 yr Check for air leaks on the box. Check twice.Then after you think you fixed any, check again.
March 16, 200916 yr Check the dust cap also.If it came even a little unglued it can make a nasty sound.
