I have 3 batts, 250amp alt, all 1/0 running 2 12"s D2 at .5 on my sundon 3000D and never and issue, I also run my 100.2 at 2ohm and no issue with it either..
I never said it was an issue, but I find it hard to believe hes staying around 13.5 @ full tilt.
here it is. 200amp iraggi alt. kinetik 1800 up front and in back, 1 run 0 gauge.
volume is 50 out of 62 in the test. the volume i set my gains at.
if you look close one i get out of the car, im not reving it anymore and it drops below 14v
Yea I have all that and mine still dips around high 12's and low 13's at full tilt, I can't see it staying at 13.5..
To bad you couldn't try strapping them at 1 ohm.
Diablo and I strapped 2 1500's at 1 ohm. Amps never got that warm.
my 2 saz1500s were strapped at 1ohm and ran at .5each and never had a problem...i had a 250amp alt 2 group 31's behind them..sundown FTW
