Will both these amps work on 15+ Volts right out of the box?
Thanks,
How much over 15v ?
The 3000D works on 18v out of the box - you only have to watch the 125.2 if you go to higher voltages. It will run up to 16.0 (sixteen point zero) volts.
sounds like someone is getting a missinglink.
Yeh, thats what i first thought as well.
Still 12v batts
