Posted April 12, 200917 yr Testing one of these out before i order 4 more to complete the setup Both amps @ .5, havent clamped them yet....i might do that today, but theyll do rated power from other peoples results ive seenFull tilt not clipping the amps itll take the power all day long....when i clip it full tilt gets a bit louder but can start to smell after a min or 2 of a constant song.Theyll be perfect with 4 2200s @ 1ohm on 4 12s..... :bigclap: :bigclap: :bigclap: VID:http://vimeo.com/4096369
April 12, 200917 yr Author nice!whats with the holes drilled in the dust cap?So i dont blow the dustcap off
April 12, 200917 yr i wonder if the sealed cap is needed for the cooling design? oh and the type R vid pissed me off so bad.
April 12, 200917 yr Author i wonder if the sealed cap is needed for the cooling design? oh and the type R vid pissed me off so bad.This is what Mark said, it was for backpressure to be released, i didnt do it if thats what you are thinking haWhy Type R vid got ya mad?
April 12, 200917 yr oh ok.i though you had drilled the holes. my bad. OH the R's/// because im doing a 143.3 in a trunked car. and a suv with 2 12 inch alpines and doing 146.XX
April 17, 200917 yr i wonder if the sealed cap is needed for the cooling design? oh and the type R vid pissed me off so bad.This is what Mark said, it was for backpressure to be released, i didnt do it if thats what you are thinking haWhy Type R vid got ya mad? I have a pair of SPL12's and they don't have holes in the dust cap. It this a recommended mod for those who don't have holes in the dust cap? Is there any noise with having holes in the dust cap? BTW interesting port setup. Can you elaborate on what you did? Thanks.
April 17, 200917 yr The reason I did that was on account that he told me he would be driving them *hard*...
April 19, 200917 yr Author i wonder if the sealed cap is needed for the cooling design? oh and the type R vid pissed me off so bad.This is what Mark said, it was for backpressure to be released, i didnt do it if thats what you are thinking haWhy Type R vid got ya mad? I have a pair of SPL12's and they don't have holes in the dust cap. It this a recommended mod for those who don't have holes in the dust cap? Is there any noise with having holes in the dust cap? BTW interesting port setup. Can you elaborate on what you did? Thanks.It helps it load a lot better than if it was just an aero out....keeps the cone under control better on the lows.And no, no noises outta it....cept LOUDNESS
April 22, 200917 yr Author That amplifier install is a bit scary... but the box looks sweet.Yesss....4400 rated watts is scary to mere mortals
June 7, 200917 yr oh ok.i though you had drilled the holes. my bad. OH the R's/// because im doing a 143.3 in a trunked car. and a suv with 2 12 inch alpines and doing 146.XXNo worries Jon I got ur back! No arrrrssssss are gonna beat this TrunkHolla!
June 7, 200917 yr That amplifier install is a bit scary... but the box looks sweet.Yesss....4400 rated watts is scary to mere mortals I think he meant by the location and orientation of the install and not the amps themselves.
June 15, 200917 yr Author That amplifier install is a bit scary... but the box looks sweet.Yesss....4400 rated watts is scary to mere mortals I think he meant by the location and orientation of the install and not the amps themselves.I picked up that, hence my joke of a response.Doesnt have to look like anything, as long as what it sounds like is nasty
June 15, 200917 yr those subs can handle more than that.Benhemp used to have a strapped pair of sundown 3000ds @ 0.5 ohm on a single SPL12 and it be fine with it.
June 20, 200917 yr Author those subs can handle more than that.Benhemp used to have a strapped pair of sundown 3000ds @ 0.5 ohm on a single SPL12 and it be fine with it.Yeh...it didnt flinch when i burped it
