Im ordering through KNU and im using a cde-102.
for powering im using **NEW** Kolossus Flex 0 Gauge Power Kit
but for rca/remote and speaker wire i have no clue.
I will be using it on a 18" fi BL. Any tips?
remote dont matter, 18 gauge is all you need.
rca's you can spend $20, and then you can spend $400 Monseter rca's, so its all in your budget. Their own Knu's are decent, Stinger, etc.
Speaker wire you want to use 12 gauge.
You can use 14-12awg speaker wire. The remote line is fine at 18awg. But use whatever you can get cheaply.
sounds good so everything I have should work right? i am planning on ordering it tonight.
yepp everything you have there will do the trick
just make sure you have enough lol
ok so the amp kit will be enough, 6m rca is the longest, remote is 20', all is left is speaker wire and whats is normal for that?
for just subs or you installn components too? if just your btl then 3 should be good, how far away is your amp thoo bro
havent done an amp placement yet but i have alot of room. its just the sub so im thinking 10 feet?
