Posted April 20, 200917 yr I have 4 Dual 2 subs and i want to hopefully run 2 3000's so each amp will see a 2ohm load. with them strapped will that make the amps run full power
April 21, 200917 yr with 4 dual 2 subs, you can run 2 subs at 2ohms to each amp for an efficient daily setup, and then rewire them to 0.5ohms per amp for competitions..i don't see any way to get 1ohm operation with those subs / amps..
April 21, 200917 yr Author i know but what im wondering when they are strapped am i suppose to be sending a 2ohm load to each amp or 1ohm to each amp
April 21, 200917 yr i know but what im wondering when they are strapped am i suppose to be sending a 2ohm load to each amp or 1ohm to each ampwhen strapped, they will function as 1 amp with a minimum impedance rating of 2ohms..
