At what resistance does your 1kw + amp do Max power? 87 members have voted
  1. 1. At what resistance does your 1kw + amp do Max power?
    • 1 ohm
      43
    • 2 ohm
      13
    • 4 ohm
      7
    • 1.5-4 ohm (regualted)
      2
    • i have multiple sub amps w/ different impedence ratings
      2
    • less then 1 ohm UNMODDED
      20
    • less then 1 ohm but modified
      0
Please sign in or register to vote in this poll.
I was just wondering what most 1kw + amps do max power at and remain stable according to manufacturer at. If your 1 ohm stable amp can go to .5 ohm stable with some modding lets classify it is as doing max power at 1 ohm for the sake of this thread. Feel free to post what amp you have, what resistance it does max power at, and what rms power at that resistance is.
  • Replies 55
  • Views 8.8k
I'll go first.
elemental designs nine.1
1 ohm
1400w or so rms
uhmm.....
what if its not 1K watts and i can EAISLY mod it to do a .5 ohm load ?
some Amps do their max at 2 ohms and drop at 1 ohm
nopt quite sure right now of the models
uhmm.....
dammit. I forgot about .5 ohm amps. For the sake of the thread lets keep this to 1kw + amps that are stable according to the manufacturer at whatever they do max power at.
welll
Its a HK-4000D
with a 1ohm load ( modded) it can do around 4K + RMS
Non modded @2 ohms its around 3600-3700RMS
I need to bench test it
what if we have one that does its power at 1 ohm and one that does its power at 2 ohms?
(Hifonics BX1500D and Tsunami DB1800T)
any mods wanna edit this poll to allow multiple votes and to include .5 ohm? I really screwed up on this one. lol.
i have 2 vipers so tech. they do power @ 1 ohm, but strapped, they do their power @ 2 ohms.
My Arc's do a conservative 1050 @ 4ohms bridged. I benched the one on the subs and it pushes 1345 @ 4ohms.
dei 1100D - 1100w@1ohm
  • Admin
the largest in my collection is the Orion 2500D, but I have a few older RFs that do power at 4ohms, but for now I voted with the Orion
I have a few amps that I can get 3k+ @ 0.35 ohm on 14.1vdc.
But I also have One amp that can knock out just shy of 2kw @3.8ohm with 15.8 vdc.
Are we assuming 14.4 vdc or 12vdc or 17vdc?
Why not just ask if the output stage is regulated....
I have a RE 35.1D rated at 1 ohm but i think it has been able to get a little more power at slightly lower resistance.
  • 2 weeks later...
i've got the orion 2500d as well...rated at one ohm..but stable UNMODDED at lower impedences, which is where i voted..
and where i run it daily..lol..
and poll edited..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
  • 3 months later...
Phoenix Gold MS1000
rated 250x4 @ 4 ohm
1060x2 @2 ohm
birthsheet
1346X2 @ 2ohm
class AB power baby!!!
Dave, do you actually use that thing? I'm guessing current consumption to be 300+ amps full tilt, little less with music? Just a rough estimate.
yes I use it-----daily-----It is going in the Magnum along with a P9 set-up (wink wink Effendi) Brahma 15 MKII etc----read the sig.
Hell I was going to run the Revo 1500.1 @ 1 ohm(1610 watts) and run the PG MS1000 to my front stage only-----headroom anyone?
