Posted May 3, 200917 yr Yes, i can get my player loose and everything, but it won't actually come out unless i take this stupid dash board brown thing out, and this is as far as i have gotten. Not sure if i was suppose to pull up the transmission trim, but whatever:
May 3, 200917 yr usually trim panels like that just pop in and pop out.The only thing you gotta be aware of is that some must be pulled apart from a certain side first or you may weaken it if popped out wrong.Search for your car online, i'm sure someone has done it before.
May 3, 200917 yr Admin http://www.metraonline.comclick products > select a vehicle > then your vehicle > in dash kits > then view the pdf thats associated with your kit, it will show you detailed instructions on how to take that out.Enjoy
May 3, 200917 yr Author http://www.metraonline.comclick products > select a vehicle > then your vehicle > in dash kits > then view the pdf thats associated with your kit, it will show you detailed instructions on how to take that out.Enjoy thank you
