Posted May 5, 200917 yr Going to make my order tomorrow for my sub(s). I want some final opinions before i do this...1 15" Deathrowor2 12" Lethal InjectionsComparing the two what do you guys think are the pros and cons of each.
May 5, 200917 yr Author its a 1998 infiniti i30, ill be using a rockford fosgate p5002 for like 2 weeks, then getting a saz-1000d
May 5, 200917 yr Author btw im looking at best ratio between sq and output. Obviously im not looking for best sq and output, just a good balance in between
May 5, 200917 yr Author So right now i have a jl 12" w3...how much more output would i get with the 2 12 LI's compared to the 1 15 DR
May 5, 200917 yr So right now i have a jl 12" w3...how much more output would i get with the 2 12 LI's compared to the 1 15 DRNo one can tell you that.
May 5, 200917 yr Author emailed Quentin (Audibel Customs) about it just now, thanks for the help guys. Ill let you know when i get it all installed hope i like it
May 18, 200917 yr depends very much how the enclosure is build.and...if they where 2x12" LI vs 1x15" LI...you all would be right...BUT...in this case it's about 2x12"LI vs 1x15" DR..the LI motor is weaker than DR's...it's another kind of driver..u can't put those in the same class...the superior cone area of the LI's are anihilated by the superior strength of the DR motor...from my experience i would say that in the proper enclosure and frec. tuning 1x15" DR would give bigger output...and would sound more clear,more correct and much more low than 2x12" LI...
