Posted May 22, 200917 yr 10,320 watts from my pair @ 1.5 ohms each actual impedance after rise, starting at 0.5 DCR5160 each17.9 volts rest - did not measure voltage drop yetThis is similar to what I got from the 3000s at a rise to ~1 ohm or belowWill post more when I get more results.
May 22, 200917 yr sounds great...PS - when we gonna get some more box gain tests, hehe. I'm sittin here in anticipation hopin u get your results done before i finish mine.
May 22, 200917 yr Author Little more testing... dropped it down to 40 Hz which is ~1.3 after rise :11,470 watts5735 per amp
May 22, 200917 yr Author Rated current draw is 350 amps.Derrick will be working on some 12v testing soon.
May 23, 200917 yr I got a little testing done. These are "unofficial" results. Until I use Jacob's equipment I won't consider it official. I did not use peak hold on my meters (and yes they are true rms). Instead I recorded my 3 meters all in real time with my camera reading ac voltage output, ac amperage output, and dc voltage input at the amplifier. Then I slowly rolled into the volume to prevent spikes and held it for 5 seconds so the readings could level off.Results:2,318watts @ 2.9ohms after rise @ 13.7v after drop. 4,040watts right around 1ohm after rise dropping to 11.3 volts. Again, these were not peak hold measurements and these are unofficial results. I'll get some official results from Jacob's equipment on Monday or Tuesday. That way all our testing will be uniform from the same meters.
May 23, 200917 yr I got a little testing done. These are "unofficial" results. Until I use Jacob's equipment I won't consider it official. I did not use peak hold on my meters (and yes they are true rms). Instead I recorded my 3 meters all in real time with my camera reading ac voltage output, ac amperage output, and dc voltage input at the amplifier. Then I slowly rolled into the volume to prevent spikes and held it for 5 seconds so the readings could level off.Results:2,318watts @ 2.9ohms after rise @ 13.7v after drop. 4,040watts right around 1ohm after rise dropping to 11.3 volts. Again, these were not peak hold measurements and these are unofficial results. I'll get some official results from Jacob's equipment on Monday or Tuesday. That way all our testing will be uniform from the same meters.Very Nice Numbers :bigclap:
May 27, 200917 yr Author I got a little testing done. These are "unofficial" results. Until I use Jacob's equipment I won't consider it official. I did not use peak hold on my meters (and yes they are true rms). Instead I recorded my 3 meters all in real time with my camera reading ac voltage output, ac amperage output, and dc voltage input at the amplifier. Then I slowly rolled into the volume to prevent spikes and held it for 5 seconds so the readings could level off.Results:2,318watts @ 2.9ohms after rise @ 13.7v after drop. 4,040watts right around 1ohm after rise dropping to 11.3 volts. Again, these were not peak hold measurements and these are unofficial results. I'll get some official results from Jacob's equipment on Monday or Tuesday. That way all our testing will be uniform from the same meters.In SPL Derrick was 1 dB up at 1 ohm vs. the 3000D!We got similar numbers on my clamp at the shop:3980 @ 0.25 rising to 0.65 @ 11.2v (engine on)2050 @ 1 rising to 2.44 @ 12.2v (engine off)
