Posted May 22, 200916 yr im wonderin what the specs will be on this amp as far as how many watts at what ohm. and i plan on gettin 2 BTL's so what VC config would i get them in and hoiw would i wire them??
May 24, 200916 yr He lies , apparently someone tested and got 4040rms @11.3volts @ 1ohmand over 2000 @ 2ohms
May 24, 200916 yr Author haha yeah i read that right after i posted the thread lol but i mainly wanted to see what ohm they were stable at. diidnt know if it was 1 or 2
May 24, 200916 yr haha yeah i read that right after i posted the thread lol but i mainly wanted to see what ohm they were stable at. diidnt know if it was 1 or 2Rated 1ohm stable but like the rest of the SAZ series amps they are tanks and will take serious abuse. The saz-3500d I've been testing has spent 99% of it's life so far @ 0.25ohm and that's where it will stay for most of it.
May 24, 200916 yr 3500 @ 11750 @ 2750 @ 4Are you serious?750 @ 4 ohms? How is this amp rated lower than the 3000?Omg I can't wait until next season. Competition Only 501-1500 is gonna be crazy!
May 24, 200916 yr The 4 ohm rating is equal to the Audioque 3500D:http://www.audioque.com/aq/AQ3500D.htmIt is based on the typical expectation of power output on a 4 ohm reactive load at 12.8 volts.
May 24, 200916 yr not sure who all has even looked at all the pics for both but I know that there is a big differance between the two!! not sure how they could be rated the same. from looking at the pics of the boards there are some important differances!! which should make a differance if final rating. but I will same that you just make stong stuff jacob!! if this is the case are you thinking of rerating the whole product line?
May 24, 200916 yr Omg I can't wait until next season. Competition Only 501-1500 is gonna be crazy!It won't be crazy at all cause the way it looks now there won't be anyone there.
May 24, 200916 yr not sure who all has even looked at all the pics for both but I know that there is a big differance between the two!! not sure how they could be rated the same. from looking at the pics of the boards there are some important differances!! which should make a differance if final rating. but I will same that you just make stong stuff jacob!! if this is the case are you thinking of rerating the whole product line?I have considered re-rating the 4 ohm power of the other amp models as well - on a reactive load most 1 ohm Class-D amps don't do a while lot at 4 ohms with 2-3x impedance rises putting the amp at 8-12 ohms most of the time.
May 24, 200916 yr Omg I can't wait until next season. Competition Only 501-1500 is gonna be crazy!It won't be crazy at all cause the way it looks now there won't be anyone there. I know of 2-3 people there will be playing in that class next season
May 25, 200916 yr Omg I can't wait until next season. Competition Only 501-1500 is gonna be crazy!It won't be crazy at all cause the way it looks now there won't be anyone there. I know of 2-3 people there will be playing in that class next seasonhmmm...
May 25, 200916 yr not sure who all has even looked at all the pics for both but I know that there is a big differance between the two!! not sure how they could be rated the same. from looking at the pics of the boards there are some important differances!! which should make a differance if final rating. but I will same that you just make stong stuff jacob!! if this is the case are you thinking of rerating the whole product line?I have considered re-rating the 4 ohm power of the other amp models as well - on a reactive load most 1 ohm Class-D amps don't do a while lot at 4 ohms with 2-3x impedance rises putting the amp at 8-12 ohms most of the time.I think that it was entended for the actual 4 ohm rating including the rise so would it be the power output when it rises to 4 ohms? and to 8 or 12 ohms?
May 25, 200916 yr All of our amps would be rated higher at all loads if we used a resistive / reactive after rise rating - they are conservative to account for voltage drops and actual reactive loads for a number that you can reasonably expect to see in a real vehicle on music program.Eg: With the 1 ohm rating you can generally expect to see that much power even after a normal amount of rise above 1 ohm.
