Posted May 26, 200917 yr ok so i hooked up my new fi ssd and my kicker 750.1 amp.ok so the problem.when i turn the volume down all the way on my kenwood kvt911 headunit. i still can hear a little bass.then when i turn it up its not loud at allll.i turned the bass up on headunit and still the same thingim soo confused someone please help
May 26, 200917 yr Maybe the subwoofer output is off on the HU. I know my HU is kinda old, so when i turn off the sub channel, and turn the volume down, I hear a little bass. Output doesnt change, no matter of volume on HU.If that doesnt do the trick, you may want to check your amp-to-sup wires, make sure the coils agree (positive wires are in positive terminals etc.) Edited May 26, 200917 yr by DeepSubBoy
May 27, 200917 yr check how u wired up the sub because u can easily over look it i did the same thing llol
