Posted June 7, 200916 yr Ok so everything is ordered and should be here within a week.Car: 2000 explorerMaterials:-Alpine cde-102 H/U-18" Fi BL with Cooling, Flatwind. D2, wired to 1 ohm.-Sundown 1500D-8cu ft. box tuned to 32hz.-KNU 1/0 amp wiring kit.-RCA's, etc all form knu-12 gauge speaker wire from KNUToo start of this is just a quick run through to make sure everything is right. First I will be doing Big 3 soon enough but for the first little bit I will be without it. Now I am keeping my stock battery and alt as the battery is very good and the alt is 130amps which should be fine for the one amp. I have installed my h/u with the remote and the rca's running down the right side of the SUV. The 1/0 gauge will be running down the left. So i will connect my amp and screw in my sub but before connecting the two I will set my gain with a multi-meter and a cd with the test one of 50hz. I am going to be running the sub at 1500w max since it is fully loaded and I have been told it can handle that. So that means I shall be looking for 38.7volts on the multi-meter when the h/u is playing at 3/4 volume, sub max, and everything else at what it will be played at when everything is ready. I know that to never play my volume at full so I will not go pas 3/4 volume which is 27 on mine. So once all the gain is set and the rest of the knobs are set I connect my sub. I will break it in for at least a good 4 hours before giving it a challenge.I am looking for any advice or if there is anything I have missed please let me know as I will not take any offense. Edited June 7, 200916 yr by LazyFcuk
June 7, 200916 yr Nice choice on amp and wiring.Thanks, any pointers on set up?Looks like your pretty prepared. I would say go for it and if you have any troubles just get on here and im sure we can help.Good luck with the install and be sure to make a build thread!
June 7, 200916 yr Author You don't need to break it in for 4 hours, get it in and slam it!always appreciate your advice but as far as tuning it and everyhting it looks good?
June 7, 200916 yr You don't need to break it in for 4 hours, get it in and slam it!always appreciate your advice but as far as tuning it and everyhting it looks good?Yeah it all looks good
June 7, 200916 yr You don't need to break it in for 4 hours, get it in and slam it!x2, ill play my subs as hard the first day as i will anyother day.
June 9, 200916 yr Did I miss anything that had to do with mid's and highs?i think he is only goin for the BASS ...
June 9, 200916 yr Nice choice on amp and wiring.Thanks, any pointers on set up?http://www.soundsolutionsaudio.com/forum/i...?showtopic=3704
