Posted June 10, 200916 yr Popular Post 187 Series 10Sealed .5 cubes - 1.0 cubes Ported 1.4 cubes - 2 cubes, 15 - 20 Inches of Port, 28-35 Hz 187 Series 12 Sealed 1.0 cubes - 1.4 cubes Ported 2 cubes - 2.5 cubes, 20 - 30 Inches of Port, 28-35 Hz 187 Series 15Sealed 1.4 cubes - 2.0 cubesPorted 2.5 cubes - 3.5 cubes, 30 - 45 Inches of Port, 28-35 Hz Lethal Injection Series 10 Sealed .6 cubes - 1.0 cubes Ported .9 cubes - 1.5 cubes, 12 - 25 Inches of Port, 28-35 Hz Average: 1.25 cubes, 18 inches, 28-35 Hz Lethal Injection Series 12Sealed .8 cubes - 1.4 cubes Ported 1.75 cubes - 2.5 cubes, 25 - 40 Inches of Port, 28-35 Hz Average: 2.00 cubes, 30 inches, 28-35 Hz Lethal Injection Series 15 Sealed 1.5 cubes - 2.0 cubes Ported 3.0 cubes - 4 cubes, 40 - 60 Inches of Port, 28-35 Hz Average: 3.5 cubes, 50 inches, 28-35 Hz Death Row Series 12 Sealed Not Recommended Ported 1.8 cubes - 2.5 cubes, 20 - 48 Inches of Port, 32-37 Hz Average: 2.20 cubes, 32 inches, 32-37 Hz Death Row Series 15 Sealed Not Recommended Ported 2.75 cubes - 4.0 cubes, 36 - 64 Inches of Port, 32-37 Hz Average: 3.25 cubes, 50 inches, 32-37 Hz Death Row Series 18 Sealed Not Recommended Ported 5.0 cubes - 8.0 cubes, 60 - 120 Inches of Port, 32-37 Hz Average: 6.5 cubes, 90 inches, 32-37 Hz Death Penalty Series 12 Sealed Not Recommended Ported 1.8 cubes - 3.0 cubes, 20 - 48 Inches of Port, 32-37 Hz Average: 2.5 cubes, 35 inches, 32-37 Hz Death Penalty Series 15 Sealed Not Recommended Ported 3.0 cubes - 5.0 cubes, 36 - 80 Inches of Port, 32-37 Hz Average: 4.0 cubes, 55 inches, 32-37 Hz Death Penalty Series 18 Sealed Not Recommended Ported 5.0 cubes - 7.5 cubes, 60 - 120 Inches of Port, 32-37 Hz Average: 6.5 cubes, 90 inches, 32-37 Hz Death Penalty Series 21 Sealed Not Recommended Ported 7.5 cubes - 10.0 cubes, 90 - 160 Inches of Port, 32-37 Hz Average: 8.5 cubes, 120 inches, 32-37 Hz Warden Series 12 Sealed Not Recommended Ported 1.8 cubes - 3.0 cubes, 20 - 48 Inches of Port, 32-37 Hz Average: 2.5 cubes, 35 inches, 32-37 Hz Warden Series 15 Sealed Not Recommended Ported 3.0 cubes - 5.0 cubes, 36 - 80 Inches of Port, 32-37 Hz Average: 4.0 cubes, 55 inches, 32-37 Hz Warden Series 18 Sealed Not Recommended Ported 5.0 cubes - 7.5 cubes, 60 - 120 Inches of Port, 32-37 Hz Average: 6.5 cubes, 90 inches, 32-37 Hz Warden Series 21 Sealed Not Recommended Ported 7.5 cubes - 10.0 cubes, 90 - 160 Inches of Port, 32-37 Hz Average: 8.5 cubes, 120 inches, 32-37 Hz Edited May 31, 201114 yr by IA2
October 30, 200916 yr So what are the recommended enclosure sizes for the 21'' Wardens???And the 18's?
October 30, 200916 yr Author Popular Post If you're buying a Warden, chances are... you don't need help on the enclosure.
November 2, 200916 yr hey john I have a question did you get a chance to play with these woofer on a spl level as well. I have the death penalty 12's and my box is 5 cu ft with 102 sq. in port by 39L it's supposed to be tuned to 37 hz if I shrink down the port to recomended how much spl do you thinkI will lose or will it stay the same my box originally had DD subs in it the DP's act a little funny in this enclosure. what do you suggest
April 22, 201015 yr Translated this list for the rest of the world who can divide by 10! Taking for granted that the original list is made in cubic feet and square inch. But still missing the port length!187 Series * 10" Dual 2 ohm * closed 22.6 - 39.6 liter * ported 39.6 - 56.6 liter, port area 97 - 129 cm2, 28-35 Hz * 12" Dual 2 ohm * closed 39.6 - 56.6 liter * ported 56.6 - 70.8 liter, port area 129 - 193.5 cm2, 28-35 HzLethal Injection Series * 10" DVC2 & DVC4 ohm * closed 17 - 28.3 liter * ported 25.5 - 42.5 liter, port area 77.5 - 161.3 cm2, 28-35 Hz * 12" DVC2 & DVC4 ohm * closed 22.6 - 48.2 liter * ported 49.6 - 70.8 liter, port area 161.3 - 258 cm2, 28-35 Hz * 15" DVC2 & DVC4 ohm * closed 42.5 - 56.6 liter * ported 85 - 113.3 liter, port area 258 - 387.1 cm2, 28-35 HzDeath Row Series * 12" DVC1 & DVC2 ohm * closed - not recommended * ported 51 - 70.8 liter, port area 129 - 310 cm2, 32-37 Hz * 15" DVC1 & DVC2 ohm * closed - not recommended * ported 77.9 - 113.3 liter, port area 232.6 - 413 cm2, 32-37 Hz * 18" DVC1 & DVC2 ohm * closed - not recommended * ported 141.6 - 226.5 liter, port area 387.1 - 774.2 cm2, 32-37 HzDeath Penalty Series * 12" DVC1, DVC2 & DVC4 ohm * closed - not recommended * ported 51 - 85 liter, 129 - 310 cm2, 32-37 Hz * 15" DVC1, DVC2 & DVC4 ohm * closed - not recommended * ported 85 - 141.6 liter, 232.3 - 516.1 cm2, 32-37 Hz * 18" DVC1, DVC2 & DVC4 ohm * closed - not recommended * ported 141.5 - 212.4 liter, port area 387.1 - 772.2 cm2, 32-37 Hz * 21" DVC1, DVC2 & DVC4 ohm * closed - not recommended * ported 212.4 - 283.1 liter, port area 580.6 - 1032.2 cm2, 32-37 HzFlatlyne Series * 12" DVC2 & DVC4 ohm * closed 28.3 - 39.6 liter * ported 42.5 - 56.6 liter * 15" DVC2 & DVC4 ohm * closed 42.5 - 56.6 liter * ported 85 liter
April 26, 201015 yr Author What is the recommended sealed box Enclosure for the Flatlyne 12"? ThanksSomeone just posted that right before you..
March 3, 201114 yr How come there are no sealed recommendations for the Death Penalty series? How will they sound sealed? SQ and loudness wise....
March 3, 201114 yr How come there are no sealed recommendations for the Death Penalty series? How will they sound sealed? SQ and loudness wise....Uh, because it is not recommended.... If you want SQ that is what the Flatlyne is for
March 4, 201114 yr How come there are no sealed recommendations for the Death Penalty series? How will they sound sealed? SQ and loudness wise....Uh, because it is not recommended.... If you want SQ that is what the Flatlyne is for It's not because of SQ, it's for the same reason the DR is ported only, it's because the sub isn't designed for sealed. Can it be used in a sealed enclosure, sure. It's against IA recommendations, and most likely will cause your warranty to be void. My DR is ported and still sounds wonderful. It's all in the enclosure.Kef
March 4, 201114 yr How come there are no sealed recommendations for the Death Penalty series? How will they sound sealed? SQ and loudness wise....Uh, because it is not recommended.... If you want SQ that is what the Flatlyne is for It's not because of SQ, it's for the same reason the DR is ported only, it's because the sub isn't designed for sealed. Can it be used in a sealed enclosure, sure. It's against IA recommendations, and most likely will cause your warranty to be void. My DR is ported and still sounds wonderful. It's all in the enclosure.Kefimsayin......
May 31, 201114 yr Sealed 1.4 cubes - 2.0 cubesPorted 2.5 cubes - 3.5 cubes, 30 - 45 Inches of Port, 28-35 Hz I edited the original post to reflect this. Sorry!
February 11, 201213 yr Depends on peak of vehicle mostly.trunk wallcurrent peak in stock configuration with my 12s is 55-57
February 11, 201213 yr Depends on peak of vehicle mostly.trunk wallcurrent peak in stock configuration with my 12s is 55-57Is this for listening to music, or competing?
February 11, 201213 yr What's a good SPL tune for warden 15s? 3000-3500rmsDepends on peak of vehicle mostly.trunk wallcurrent peak in stock configuration with my 12s is 55-57Is this for listening to music, or competing?What's a good SPL tune for warden 15s? 3000-3500rmsmost likely building two ports one daily one spl. Just need loud for sbn
February 14, 201213 yr Daily: just going to say 30hz so you won't miss anything on those bass cds, rap, and so forth.SPL: Your going to want to do some testing, otherwise try 40hz or so.Broad answers here.
