Posted April 25, 200521 yr lets say i get this amp:http://shop.vendio.com/inetdistributors/it...7115/index.htmland run 2 coaxes off 2 channels for 60-70w @ 4 ohms eachand run 2 subs off the other two channels for 150w @ 2 ohms eachrun rca's from the rear channel jacks in the amp to the sub control jacks in the HU, will i be able to control the subs from the HU?
April 25, 200521 yr Run the front to channels 1&2 and run the sub to channels 3&4.Yes, you will be able to control the subs from your H/U if it has features like that
April 25, 200521 yr Author Run the front to channels 1&2 and run the sub to channels 3&4.Yes, you will be able to control the subs from your H/U if it has features like that<{POST_SNAPBACK}>okay cool, thanks supayou can delete this thread now admin.
