July 10, 200916 yr Author Thread rod in for bracing. the nuts aren't on yet, the box that I thought I had left over from mine had 2 in it lol.
July 12, 200916 yr Author All painted, and it's actually a box now. All that's left is to run the wire to the sub and maybe some touch ups to the paint.
July 12, 200916 yr Author Over spray ftl. Box itself finished. Now to just mount and wire the sub and put it in the car, possibly some led's.
July 12, 200916 yr Author It's all done and in.There is one thing though, at higher volume the sub cuts out, then comes right back on when the volume is turned down a couple notches. I was thinking something could be loose, but everything was solid......Any ideas what it could be and how to fix it?
July 12, 200916 yr have you guys let it break in yet since you bought or did you put it in their throwing full power at it
July 13, 200916 yr Author have you guys let it break in yet since you bought or did you put it in their throwing full power at itHe got the sub used and the amp new.
July 13, 200916 yr Is your problem amp related? Drivers either work, or not. It sounds like protection circuits are kicking in on your amp.JP Edited July 13, 200916 yr by zora
July 14, 200916 yr Author Is your problem amp related? Drivers either work, or not. It sounds like protection circuits are kicking in on your amp.JPI'm thinking that or bad connections.
July 18, 200916 yr Is your problem amp related? Drivers either work, or not. It sounds like protection circuits are kicking in on your amp.JPI'm thinking that or bad connections.if your able to know on what song it happen and what volume try it again hopefully it doesnt cause damage to your subs. ask a friend to crack it up for you while you look at the amp if it goes into protect mode
